We are all familiar with the webstore RockAuto.com. They have an astonishing number of parts.
I found something useful about their web store last evening that helped a bit. I needed a new wheel cylinder for my 1956 Packard Clipper's LR brakes (yes, it is different than the RR!). I might have been able to rebuild the old one in terms of honing the casting, but the pistons were too badly corroded to reuse, and pistons no longer come in rebuild kits.
RockAuto showed that they had new wheel cylinder assemblies, much to my surprise. Then I noticed why. In the RockAuto listing for a given part, they give you competitor brand part numbers, so you know what other makes the part you need will fit, if any. In this case, I recognized the part number for the Packard wheel cylinder as also having three different Ford applications. That confirmed, thank goodness, that it was not Packard-exclusive.
RockAuto had the wheel cylinder assembly if I wanted to order one. But I took the numbers up here to AutoZone and they were able to get me a wheel cylinder by noon the next day, for only $11.19! That was about the Rock Auto price with shipping. So the job was all done and the car was back on the ground with the brakes bled, within 24 hours of when I determined what was causing that wheel to hang up.
So RockAuto's website is handy even if you don't buy anything from them on that visit; it can tell you if the part you need is common to other applications, and thus more readily available. BP
