v-8 fuel pump??
  • v-8 fuel pump??
Name:	fuel pump s.jpg
    My fuel pump (with glass bowl) is leaking. I am confused as to which one to replace it with. Mine has a glass bowl but the replacement glass bowl version isnt listed for a 1959 lark 259 v8.
    can I get a replacement to match this from a vendor here such a Stude Int. or should I get a rebuild kit that I did find listed for the glass bowl type pump.
    thanks
    Dave
    I have the same one on a shelf and will be putting a kit in it for future use Yes, V8- Mine is a Carter. I suppose the filter may come clean with some type of solvent. Although someone might have it. Let me know if you find a source. cheers jimmijim
      It's important to know what the fuel pump is leaking. Is it leaking gas or oil? Where is it leaking? Is it leaking around the mounting gasket, fuel bowl gasket, diaphragm, or pivot pin hole?
      There are some leaks that can indicate that the gaskets need tightening or replacing, but the fuel pump itself is OK. A perforated diaphragm will always mean rebuild or replace.
        Contact Dave Thibault. Put his name in the Advanced Search box upper right of this page, or look in the card file section last page or so of Turning Wheels. He has all and knows all of what you speak.
          Just to add to what JClary said, be sure it did not allow gas into the oil. Smell the dip stick and look to see if you are magically gaining oil!
            The OP's Pump IS a real Carter and very much a keeper, you need to get the Studebaker Vendor re-build Kit for this type, rather than an inferior New Pump.
              the leak appears to be coming from between the 2 halves that are bolted together. There is no extra oil in pan and the pump still works fine. Its just leaks (externally)
              So if this pump is a "keeper" then I assume I should just get a kit to rebuild it???
              thanks for all the info guys .......this is my 1st Stude and somewhat confusing to me.
              Dave
                Really no matter where the fuel comes from, we can be sure since it is the original OEM Studebaker type Pump that, if not original to the Car, it is quite old and ready for the Ethanol Resistant Diaphragm included in the Kit anyway. So yes rebuild it.
                If the stone filter cannot be blown out clean with compressed air or soaked to clean it up, there is a screen supplied in the kit to replace it, or some kind of paper Fuel Filter could be modified to fit it like used in the '63-'64 metal bowl Carter pumps.
                  fuel pump
                  Dave
                  There are a variety of fuel pump configurations that will fit the only important part is the pump lever. These pumps can be configured in a variety of ways, with no bowl, metal bowl, short or long glass bowl, they all work the same. Also the top components are interchangeable with many of the lower components. Over the years anything could have been mixed and matched. I have a box of about a dozen fuel pumps and I was able to mix and match just about every combination. As far as "rebuilding" that can be all things to all people. The kits usually do not come with the diaphgram preattached. I rebuilt all the pumps I have and the kits come with the diaphgram loose and must be reattached to the brass plunger assembly.This is where it gets trickey, some rebuilders grind the rivet off to detach the old diaphgram and drill and tap the center of the shaft and reattach with a machine screw, while others press the rivet apart with a hydraulic press with out wasting any material and rerivet the assembly back together. I have done it both ways but I prefer the pressing and reriveting, when the job is done you can't tell it was ever apart. Both procedures require a reasonable amount of care for a good job. If a kit is available with the diaphgram preattached all the better, it will cut the work in half, but it is still trickey to separate the fulcrum arm from the diaphgram. With some limited perserverance it is doable. It would be a whole lot easier to buy a replacement pump. Dave
                    altair (Dave) man, I don't have any idea WHERE you are getting your "unattached Diaphragms" but you will scare away any novice backyard Mechanics with all this extra very difficult work!
                    Those of us in the SDC know to buy the kits from Studebaker Vendors, and they are a "drop-in" installation.
                      thanks everyone for you replies. I ordered the parts today. if i screw up the rebuild I can order another kit!!!!.
                      Dave
                        Very well and good to know I got my kits from Houghton in NewYork thanks Dave
                          Isn't the Web a Wonderful thing Dave?
                          You NEVER know WHAT you are getting, unless you have actually been to their "Brick and Mortar" Building!
