I spent some time over the weekend scraping and removing freeze plugs from a 259 V8 block I have had on an engine stand for quite a while. The block has a small ridge and looks fairly clean inside. If I was really cheap I should have put it back together years ago just to get by.
What I am debating is the question of 259 or 289. The transmission I will probably use is a T86 three speed I built from a standard wagoneer transmission and a taxi transmission. I have a R series cam regrind on the shelf and I have a 259 NOS crank which I could buy standard bearings if I go the 259 route plus new pistons.
I have a 289 crank that needs machining, how much I have no idea but I would also need bearings, pistons and the works.
Costs may be equal in the long run due to price differences in pistons and the like...
Which would you build?
Jeff T.
"I'm getting nowhere as fast as I can"
The Replacements.
Jeff T.
The Replacements.
