My avanti is just 1 year off a complete restoration, yet I discovered a fuel leak on the short piece of hose between tank outlet and stainless steel line running to the engine bay. I thought my differential cover gasket was leaking but when I crawled under the car I found a drip drip drip of gasoline coming from above the differential. Apparently the 3/8" fuel line looks like it was a bit frayed through outer casing like it rubbed on something. My avanti is stored in a metal shop garage with race deck tiles and apparently the gasoline was getting underneath the plastic tiles and evaporating before I ever noticed it. The last time I used the avanti the tank was full so over the last month approximately 20 gals dripped out. I managed to wrap a short section of fuel hose around the leak and put a clamp on it until I could drive to a buddy's tire business after he closed today so that he and I could put the car up on his hydraulic rack and replace the fuel line. We also adjusted e-brake cable, tightened lose exhaust pipe to header connection and changed the oil while at it. After doing so the car is starting and running a lot better as apparently the fuel pump was pulling in some air through the leaking fuel hose. Afterwards I took him and his wife out to dinner to thank him for letting me use his lift and tools. I am so thankful this situation ended as well as it did, if the leaking gasoline had caused fumes to built up and an ignition source ignited them it would have been catastrophic for the Avanti and the 51 Champion.
Lesson learned ..... thankfully the easy way versus the hard way.
