My 53 Commander has a positive ground, the car still has the 6-volt system I would like to get rid of this has anyone done this and if so whats it take.
Positive ground
I can see no earthly reason to change a six volt positive ground car to six volt negative ground. There's nothing to be gained from it, unless perhaps you have a six volt negative ground transistor car radio to install.
If you switch to 12 volts, then a switch to negative ground would be a normal part of the modification.
Studebaker used positive ground on six-volt cars because they thought there was technical advantage to it.
If you really want to change the system polarity you will have to: reverse the battery, switch the wires on the ammeter, switch the wires on the low-voltage terminals of the coil, and "flash" the field on the generator. The tube radio ought to work with reversed polarity; at least it won't burn up.
Gord Richmond, within Weasel range of the Alberta BadlandsGord Richmond, within Weasel range of the Alberta Badlands
Tube radio in positive ground car has a vibrator that is polarity senstive. The filaments don't care about polarity but the vibrator most be changed to a negative ground type if you
change to 6 volt negative ground--which seems a waste of time and monry IMHO.
...DickThe 1950 Champion Starlight
Santa Barbara
CA
My 52 ragtop is still 6 volt pos. ground, with a 289 and late model flight o matic in it. my 52 cranks over just fine. I also have had my radio converted to am/fm and I also had the shop add in a 2nd converter and I run a 6 cd changer on the 6 V pos. ground.
I don't understand how a 12 V neg. ground cd changer works through it, but it does, I hardly listen to the radio, mostly cd's.
The down side is, I could have bought a NICE 12 V stereo for what I have in the whole thing. But, it looks all original.
My radio was done by www.turnswitch.com
Jim
