Hi, Guys,
It's been a while since I have posted, though I still lurk in the shadows.
I have completely reconstructed a basket-case '63 Avanti R-1. Engine rebuilt by a competent shop and gone through by one of the few guys left around southwestern Connecticut who still understands these engines.
Here's the problem: slow cranking although it cranked fine not long ago.
History:
Car came with a Thibeault/Chrysler HEI ignition. I duplicated what was in there rather than go back to stock or rewire for a Pertronix.
Sent the car to the shop for ignition setup and to get the car running. Shop returns the car in running condition, which is to say starts right up and pleasingly loud owing to the glasspack mufflers from Silvertone Exhaust, but carb and choke not yet tuned.
Shop man gives me homework, to wit, alternator is not charging the battery and power steering valve is leaking like a sieve. Keep in mind as you read on that she started up like a champion (no pun intended) as long as there was sufficient charge in the battery.
So here's what I did:
Replace alternator with a Nippondenso 60 Amp per instructions on Bob Johnstone's website. Very easy I add for those who are considering it and much cheaper than a rebuilt Prestolite. Added bonus, no need for a voltage regulator. But I digress.
Have Jon Myer rebuild power steering valve, which he does in a day. Turnaround is rapid and no more little pink puddle under the valve.
To get the valve out and then back in I have to yank the starter. Difficult on one's back but doable.
After everything is back in, replace the starter and reconnect the battery.
Charge battery to full.
Now the fun starts. Very slow cranking. Not enough to fire the engine, where it could do so before.
Take out the starter and spin it with no load. It spins rapidly.
Put the battery back in and jump from the +terminal on the battery to the starter post. Plenty of spark but no go. No spin at all. She won't budge.
Put the battery cables back. Recheck all grounds.
Pull the spark plugs and spin the engine with no compression. Spins acceptably well.
Put the plugs back in and restart. Sloooooooowwwwww crank.
So it seems to me either the starter doesn't have enough oomph to spin the engine under compression or there's not enough voltage getting there. Starter is the correct 4-pole Prestolite MDU model.
What do you guys think? Any thoughts are gratefully welcomed.
Tested for current draw and there is none.
Thanks,
Tom
History:
Thanks,
Tom
