When I turn off the wipers they park in the middle of the windshield instead of at the base of the windshield. How can I get them to park at the base of the windshield?
The windshield wipers are finally working but...
The Park switch is likely Bad if the motor is wired correctly. It is the tiny little switch where the wires connect to the Motor (indirectly).
What did you do to make them work? If you removed the 3 wires, it is best to check the wiring diagram.StudeRich
What has been done to the wiper system since they last worked correctly?
It is most likely in the park circuit, as Rich mentioned, but it could be as simple as you put the wiper blades on in the incorrect position (the motor wasn't at park when you reinstaled the blades, hopefully at the w/s base).Gary L.
Originally posted by StudeRich View PostThe Park switch is likely Bad if the motor is wired correctly. It is the tiny little switch where the wires connect to the Motor (indirectly).
What did you do to make them work? If you removed the 3 wires, it is best to check the wiring diagram.Peter Bishop
Regarding the park adjustment, page 12B in the Body Section of the Shop Manual (59-64) says "To adjust the parking position move the contact plate to the rightor left as necessary to provide the correct parking position."
What and where is the "contact plate"?Peter Bishop
Originally posted by PeterHawk View PostRegarding the park adjustment, page 12B in the Body Section of the Shop Manual (59-64) says "To adjust the parking position move the contact plate to the rightor left as necessary to provide the correct parking position."What and where is the "contact plate"?StudeRich
The contact plate is the round metal cover that the wires attach to. You will notice that the outer plate can the rotated - it pivots at the center and there is a small "tab" on the outer plate. Push on the tab with a flat bladed screwdriver - this changes the position of the contacts on the cover to the "park" contact area on the gear, enabling you to adjust where the wipers will park.
Originally posted by Studebakercenteroforegon View PostThe contact plate is the round metal cover that the wires attach to. You will notice that the outer plate can the rotated - it pivots at the center and there is a small "tab" on the outer plate. Push on the tab with a flat bladed screwdriver - this changes the position of the contacts on the cover to the "park" contact area on the gear, enabling you to adjust where the wipers will park.Peter Bishop
Originally posted by PeterHawk View PostJerry, Thanks for the advice. I'll be in the garage tonight.
I realize the above is about as clear as mud. But since you have been fooling with it recently, hopefully it will make sense.Last edited by JoeHall; 09-03-2013, 03:50 AM.
wiper motor
Here is a twist,
My 56 wagon, the wipers run and park fine. BUT, when I go over 40 mph, its like the wiper arms are slowly "wind blown" up, to the vertical position.
Its almost like there is something loose in the drive. But you cannot grab the arms and return them to park. You have to turn on the wipers and re-park them. (several times if you are driving while doing it)
I have to assume the motor is running super slow till the wipers reach straight up, them it stops there for some reason. It does it every time I drive it.
Any thoughts?
(I asked a couple of weeks ago about how to connect my wiper-motor after I had it re-wired to 12 volt & never even got one reply... I had lost my photo's of the contact I took before I took it appart, I tried a few times & in the end I reckon I got it right but now it only works full speed.)
Now then, about this:
When I re-installed the stuff & started I was also surprized to finding the wipers stopping almost straight up!
Then I went out of the car & losend them from the splines & put them back on in the right position...
