I posted a while back on the wipers, and then the subject went over to the radio. I thought I should ask this question in the electrical section. I will start with a quote from RadioRoy from that post: If you replace the vibrator, you should also replace the buffer capacitor (the 1600 volt one) and the electrolytic capacitors in the power supply.
You can just throw a new vibrator in there if you like, but do not be surprised if it has a shorter lifespan than you anticipated.
Additionally, make sure the battery in your 47 is hooked up positive ground. Many solid state devices, like the new vibrators, die instantly and violently with reversed polarity.
I have the vibrator now and I also got a radio factsheet with the schematic. Looks like the buffer 1600 Volt one is the #13 one at 1600 Volts and .006 micro farads. The electrolytic one - is that #9 A,B,C, and D can capacitor with 4 Capacitors built in? If it is, would anyone (probably you Roy!) know of a good source for it? The Mallory # is FP424.
Thanks very much
Neil
Thanks very much
Neil
