hello all , i have just fitted a pertronic ign system to a R1 distributor and installed it into a 1957 v8 hawk , runs well but i noticed the ballast resistor is very hot to touch ,question is, does it matter which side of the ballast res the wire goes to from the distributor . i lost the guide sheet so wasnt sure , thanks for your help. roger
pertronics ign system /hot
No problem, the ballast resister is supposed to get hot. You only need to use that resister IF you are still using the OEM coil. If you use an aftermarket coil with internal resister, you can bypass it. When it comes to starting and performance, cannot tell any difference no matter which way they are set up.
Originally posted by studevic View Post/Cut/question is, does it matter which side of the ballast res the wire goes to from the distributor . i lost the guide sheet so wasnt sure , thanks for your help. roger
I don't care what Pertronix says about their coils being able to operate without a ballast resistor, don't do it. I've replaced 3 Pertronix coils that have failed in recent history due to overheating from high primary winding voltage. A ballast resistor or a coil with an internal resistor is required with a 12 volt ignition system. I agree with Rich, a 12 volt coil is designed to operate on 8-10 volts, any more than that and the coil windings overheat. The ballast resistor is non directional and is connected in series with the positive lead to the ignition coil from the ignition switch and is bypassed by an extra connection on the starter solenoid during starting to allow the coil to temporarily operate on a higher voltage during starting. Bud
Originally posted by Bud View PostI don't care what Pertronix says about their coils being able to operate without a ballast resistor, don't do it. I've replaced 3 Pertronix coils that have failed in recent history due to overheating from high primary winding voltage. A ballast resistor or a coil with an internal resistor is required with a 12 volt ignition system. I agree with Rich, a 12 volt coil is designed to operate on 8-10 volts, any more than that and the coil windings overheat. The ballast resistor is non directional and is connected in series with the positive lead to the ignition coil from the ignition switch and is bypassed by an extra connection on the starter solenoid during starting to allow the coil to temporarily operate on a higher voltage during starting. Bud
With one of the cars, when I had a distributor cap problem and was troubleshooting, I swapped the OEM coil back in and reconnected the ballast coil. I could tell no difference in start up or performance, so after eventually replacing the distributor cap, was in no hurry to swap the 8140 back in. I eventually did, but still cannot tell the difference. That's why I mentioned it above also.
I agree, stay away from the Pertronix coil, no matter how you hook it up. Looks like its bad rep extends from coast to coast
Originally posted by speedbump View Post18K miles on Pertronix and coil and zero problems with no resistor.(ugly on firewall) The ballast was put in to protect the breaker points, not the coil.
Glad yours is working out. However, its good practice for any Stude driver to carry a spare coil in the "insurance items" box in the trunk anyway. I do, and hope you do too
There is nothing wrong with using OEM or aftermarket stock coil as long as it is in good condition. All of the hype about using a hotter coil on a Studebaker engine makes little sense as our engines are for the most part are lower compression slow revving engines that don't need a super high output coil as they don't require a high firing voltage to light the plugs. The Pertronix module will work just fine with a stock coil. I have stock coils on both my 62 Hawk and my 63 Avanti and have had no problems with coil failures like I've had with the Pertronix or other supposed high output coils. Keep in mind that the new replacement coils are no longer being produced in the USA and their quality is suspect at best along with other ignition parts that I've purchased in recent history. Bud
I make some retired 'beer money" by machining and building older engines for people that desire them....and are willing to pay. That includes Studebakers. I convert all that I do to Pertronix and I use thier coil, not for killer spark or any of the advertising hype, but because I think it's easier to talk to Pertronix if you have a problem and you use their "system." So it makes it easier for my customers and have had zero problems. Neither of my hot rods, to this point, are Studes(even though they put a smile on my face) but they both have pertronix for the reasons stated. In my 66 years of being in this stuff as a business, vocation and hobby, I can't think of one time right now that it really was the coil that was the problem, but it seems that's the first thing blamed when there's an ignition problem. Maybe I can't remember cuz I'm old, but I don't carry a coil in my possibles bag.
Originally posted by speedbump View PostI make some retired 'beer money" by machining and building older engines for people that desire them....and are willing to pay. That includes Studebakers. I convert all that I do to Pertronix and I use thier coil, not for killer spark or any of the advertising hype, but because I think it's easier to talk to Pertronix if you have a problem and you use their "system." So it makes it easier for my customers and have had zero problems. Neither of my hot rods, to this point, are Studes(even though they put a smile on my face) but they both have pertronix for the reasons stated. In my 66 years of being in this stuff as a business, vocation and hobby, I can't think of one time right now that it really was the coil that was the problem, but it seems that's the first thing blamed when there's an ignition problem. Maybe I can't remember cuz I'm old, but I don't carry a coil in my possibles bag.
Originally posted by speedbump View Post/Cut/I can't think of one time right now that it really was the coil that was the problem, but it seems that's the first thing blamed when there's an ignition problem. Maybe I can't remember cuz I'm old, but I don't carry a coil in my possibles bag.
