You are welcome to give me a forum spanking for not doing a topic search first...but, I'm just too lazy.
Anyway, I don't recall this being discussed before. I came in for a rest and decided to ask this question before going back out in the heat and humidity. I have never opened a brake cylinder for rebuilding that did not have some form of nasty, gooey mixture of brake fluid and corrosion between the rubber dust cover and aluminum brake cylinder pistons. If you allow it to dry, it will turn into a somewhat white flaky substance. (I have heard it referred to as "metal salts")
I use dental picks to scrape and gouge the stuff out and then a wire wheel brush to do the final cleaning. My normal way of rebuilding brake cylinders is to clean all the reusable parts a good as possible...hone the cylinder using brake fluid as a lubricant for the hone. Then I clean the cylinder with brake fluid, and make sure that all parts are coated in nothing but fresh brake fluid before assembling the cylinder.
My question ...is there any coating or treatment for the external portion of the cylinder that would discourage the formation of the corrosion that takes place between the rubber caps and the pistons? So far...I don't know of one. Seems like no matter what you do, sooner or later, corrosion forms, builds up, interferes with the operation of the cylinders and eventually, destroys the aluminum pistons.
