I have seen a diagram of what engine goes to which hole on the mounting plate on the frame does anyone have that ? I just got a truck with a bad drive line vibration already gone through normal stuff u-joints-drive shaft alignment remove lowering blocks etc. figure this is problem and don't want to change it but once. any help would be appreciated
Engine mount description
This Forum is for Forum related problems not Car issues, I see you are New, so I am sure you did not notice that. Just copy this question and paste to a New Post on the Technical Forum and you will receive more help where it will be found.
Welcome to the SDC and to the SDC Forum.
Thanks.
Originally posted by rustywire48 View PostI have seen a diagram of what engine goes to which hole on the mounting plate on the frame does anyone have that ? I just got a truck with a bad drive line vibration already gone through normal stuff u-joints-drive shaft alignment remove lowering blocks etc. figure this is problem and don't want to change it but once. any help would be appreciatedStudeRich
Hey Larry,
What year and model truck is it? Someone with a Chassis parts book for that truck might have exactly what you're looking for.
Oh, and once again, welcome to the forum!!Last edited by JimC; 09-02-2013, 08:17 PM.'63 Lark Custom, 259 v8, auto, child seat
Ok, our wonderful Moderator Clark (showbizkid) at work! This post was in the Forum Issues Forum called "Forum Discussions" and moved to a better place where it will be seen, Thanks Clark.
Basically Larry, Studebaker Engines always go to the Right Side Holes in the Mount Brackets when there are both Left and Right Holes.
The Left Side Holes are only for Right Hand Drive Vehicles, the purpose is to clear the Steering Gear and align it to the Driveline.
Usually, the Fore and Aft holes as on C & K Models are for the 6 or V8 to fit the frame properly. It would help to know what Model and Year you are working on.Last edited by StudeRich; 09-02-2013, 08:36 PM.StudeRich
Thanks for all the responses I am sorry but this is a 1963 E8 3/4 ton 259 V8 3spd w/OD I realized I did ask a dumb question before I researched the frame ( I have owned several cars this is first truck) but this problem just will not go away I have replaced all engine mounts, carrier bearing bushings, spring bushings, aligned drive-shafts and still have drive line vibration starts around 2500 rpm (45mph) and gets worse at greater speeds I now have the truck on jack stands and still get vibration Can the harmonic balance cause this? How do I check that? anything else you may think of I will try
Thanks
Originally posted by rustywire48 View PostThanks for all the responses I am sorry but this is a 1963 E8 3/4 ton 259 V8 3spd w/OD I realized I did ask a dumb question before I researched the frame ( I have owned several cars this is first truck) but this problem just will not go away I have replaced all engine mounts, carrier bearing bushings, spring bushings, aligned drive-shafts and still have drive line vibration starts around 2500 rpm (45mph) and gets worse at greater speeds I now have the truck on jack stands and still get vibration Can the harmonic balance cause this? How do I check that? anything else you may think of I will try
Thanks
Found the post I had remembered and it was in the technical forum here.
\'57 3E6-12 Transtar Deluxe
\'64 Daytona HT
