So another query; I have two engines, a 1962 and a 1963. Both have the oil pump beneath the block. Other that the intake manifolds, which are both four barrel but the newer one has larger secondary ports, is there any differences in the motors?
Changes between years for 289 engine
No there is no difference, IF you are talking about them both having a Oil Filter Adapter on the right rear lower side of the Block.
They all have the Oil Pump in the Oil Pan.
The '62 would have to be a late '62, with the Valve Covers with Oil Caps, and no Oil Filler Pipe to have that feature.
The '62 Intake fits the square bore Carter WCFB four barrel, and the '63 fits the Carter AFB (and Edelbrock AFB clone) 4 Brl. Carbs.Last edited by StudeRich; 08-25-2013, 06:23 PM.StudeRich
Thank you Studebaker Center of Oregon for clarifying the oil filler pipe issue for me. I have a late '62 full flow with the oil filler tube (and no breather caps on the valve covers) and I was uncertain if someone had changed some things. Looks like it is original (now if I can only get it unstuck!).Howard - Los Angeles chapter SDC
'58 Packard Hawk. A partially restored car that was not completely assembled.
