I know things are not supposed to go as planned in this hobby but I just hit the jackpot. I bleed the 74 Avantis brakes with an HF vacuum bleeder and in less than 30 min. the pedal is up better than 1/2 with no booster help. You can push the pedal hard and no movement.
Why/How -- !!
The system is totally new. Ford dual master cylinder, proportioning valve, Line Lock solenoid, all new lines, Turner front brakes and all new rear cylinders and shoes.
Hooked up the HF vacuum system to the right rear cylinder and pulled the trigger. It took a while but fluid started slowly to come out. It never got to a stream just kept coming. Let an ounce or so accumulate and thought the line can't be full. So pulled the line off the fitting and put on a clear line. Opened the bleeder and a steady stream of fluid started out. Shut it off and did the same thing to the other three wheels in the typical order. Cracked each valve after using the pump on them and fluid ran out so I tried the brakes, Hard pedal. Waa-Hoo.
Interestingly, I never bench bled the M/C as the Internet said that it wasn't necessary. It wasn't. You can see the amount of DOT-5 I used as the clear bottle was about 3/4+ full when I started.
Just love it when the Internet is right and something works as it is described. Best $20 I've spent in a while.
Bob
Why/How -- !!
Bob
