I did a search but couldn't find an answer. On a 6V positive ground system, does the positive side of the coil go to the points or the negative side? Thanks Tom
Positive ground, 6V system coil
Originally posted by Buck View PostI did a search but couldn't find an answer. On a 6V positive ground system, does the positive side of the coil go to the points or the negative side? Thanks Tom
And Ground to ground ie Points (+).
Originally posted by StudeRich View PostNo mystery, it goes to the same place as a 12 Volt, Hot to Ign. Switch (-)
Corley
