View Full Version : Help me choose mufflers.
rknight89
08-13-2013, 12:50 PM
The Lark is FINALLY almost done! Soon it will get a new exhaust system. I think I want dual exhaust, but I'm not sure what kind of mufflers to use. It has a rebuilt 259 and I think it could sound really good with the right mufflers installed. I don't want it LOUD:eek: under normal driving. I do however want to hear it if I get on it a little bit:whome:. I've heard some SBCs that sound great and I know of a flathead Ford V8 that you can't hear running but if he gooses it, it sure sounds nice:!:. Also, I'm not looking for that 'cackle' on deceleration. I guess I want something fairly mellow that can still make some noise when provoked:!!:. Any suggestion, thoughts and comments would be appreciated and considered (and possibly ignored).
Dan White
08-13-2013, 12:55 PM
contact Don Simmons, one of our Stude vendors that makes complete stainless steel exhausts, plus SS mufflers. He has quiet and medium tone (plenty loud) for all Studebakers, has loud for Avantis.
http://www.studebakervendors.com/silverto.htm
RareBird
08-13-2013, 01:00 PM
I made a mistake and put his quiet mufflers on. Now I sit at the light looking at the Tach to make sure it's still running.
rknight89
08-13-2013, 01:04 PM
Yeah...I don't have a tach so I want to be able to hear it, but I'm not looking to rattle the windows. I want opinions from people who have tried various types or brands of mufflers and what they liked or disliked about them.
'66Commander
08-13-2013, 01:07 PM
Not to be one of those folks, but I'm on the same boat with my commander. I want to put duel exaust on it, and still be able to hear it. but not rattle everything in a 10ft radius.
JoeHall
08-13-2013, 01:11 PM
Just take it to PayLess and tell them what you are thinking, as far as noise is concerned. They will hook you up, while you sit in their lobby and sip coffee.
08-13-2013, 01:12 PM
1. Definitely buy stainless and you'll be done with it.
2. Definitely have some sort of crossover connection between the two sides. It can be a simple "H" or a fancy "X". This is necessary to prevent the steady speed highway resonance/drone which can drive one nuts in short order.
3. Sound is so relative. One old Studer my age thinks his Avanti sounds perfect. His grandchildren can't stand to ride in it, especially in the back seat. Old ears don't hear what young ears hear. Back seat sounds different than driver's seat. Windows up with AC on sounds different than windows down. High compression/longer cam R1 will sound different than standard compression 259". Short wheelbase Lark/Avanti/sedan will sound different than long wheelbase C/K/GT. Bystanders hear a different sound than occupant; that car which sounds so great on driveby might not be so tolerable inside.
4. Don't get carried away on larger pipes. Even 2" is overkill for a 259". Chances are, that flathead you liked so much might have small diameter pipes. Appropriately sized pipes are less expensive, easier to route, run warmer and sound better on a small engine.
5. Finally, you're not marrying the mufflers. Try the medium tone. If you think they're too loud, you will always be able to swap for the quiet tone and get back what you paid for the medium.
6. FWIW, most old ears don't care for the hollow "flowmaster" sound the younger pony car crowd likes so much.
Your opinions and results may vary.
jack vines
sweetolbob
08-13-2013, 02:50 PM
Go to the major muffler manufactures websites, they have a ton of sound files of different size, type, and HP engines with a variety of their mufflers. That will give you some idea of what to look for. I have Don's SS system with Magnaflow oval glasspacks 2 1/4" on my 355 SBC Avanti and it fits well and sounds they way I like 'em.
My 74 will be louder and have a shorter system made locally from mild steel.
Only you know the price point and sound you want so start with the web sites.
Bob
LeoH
08-13-2013, 03:35 PM
This question comes up occasionally on the HAMB and one tip I've learned from there is to find out a brand of muffler, X, Y or Z and go to YouTube and do a search; odds are you'll be able to find someone who has a video posted with the sound of that muffler running and if not with your particular engine, certainly one close.
You can even find sounds of single, dual or H or X crossover pipe sounds, depending.
rknight89
08-13-2013, 09:07 PM
THANKS for the input guys!!!! I'll have to talk to some exhaust people and make the call myself. I realize 'sounds good' is very subjective. Just wanted some opinions. Anything I SHOULDN'T do?
Corvanti
08-13-2013, 09:42 PM
unless you have an excellent speaker system hooked up to your 'puter, use headphones/ear buds to hear them.
use the factory or supplier sites to listen. the you tube sites "may" also have headers/larger pipes, etc. make sure they are close to what you're looking for in pipes, etc. if noted on the video/audio.
everything Mr. Vines stated above.
i'd go with the stainless - medium as mentioned above.
my $0.02 :)
Dougie
08-13-2013, 09:51 PM
For what it's worth, while stainless steel is great because it doesn't rust, my experience is that is gives the exhaust a "tinny" sound. It did it on my Firebird, and my TR6. Mild steel just sounds better, so that's what I put on my Lark 327 Chevy.
Flashback
08-13-2013, 10:15 PM
The plain and simple answer is Smithys mufflers.
okc63avanti
08-13-2013, 10:30 PM
Flowmaster Series 40's really nice under acceleration and at speed are a low resonance sound.
rockne10
08-13-2013, 10:58 PM
I put his quiet mufflers on Désirée and I'm glad I did. Folks in front of you don't hear you coming; those behind you KNOW IT !
My elderly neighbor says they wake her when I arrive home but adds, it's a very mellow awakening. :!:
jeds55
08-14-2013, 06:34 PM
Borla - 1 in 2 out
Everything you can ask for, using stock exhaust headers.
