In reading a recent thread about what can heppen if the crank bolt isn't properly torqued i decided to double check the torque on mine, as well as the crank fan drive pully.
I also became a little concerned because the crank fan drive pullys wobble ever so slightly when the car is running. I don't know what the actual runout is but it is visible although I have experienced no vibration associated with that. Thoughts?
Anyway, back to torque... Book says the crank fan drive pully is to be torqued 15-17 f.p. (180-204 i.p.). i used my inch pound wrench at what I believe is 192 and was careful to alternate nuts as I would putting on a wheel. It seems to me that that is not much torque as it is still pretty easy to tighten/loosen the nuts. Should I locktite these?
I have ordered a new crank nut lock plate as mine has been "massaged" so many times I am also worrying whether it is ineffective. Then, I don't know if I can trust my big f.p. torque wrench's accuracy.
Of course, maybe my Harbor Freight torque wrenches are crap. Well, I expect them to be less than professional quality but should a feller not skimp when it comes to a torque wrench? What brand and style are you using that you have confidence in? Digital? Twist to set? Original pointer style?
