Ok, I do not know what this piece of rubber is called. It isn't the "door seal" (door to bady). It is a piece of rubber that is in between the door frame and the removable interrior window frame piece.
Is this enough information? What is this rubbed called and is it available anywhere for the 1940 commander sedan?
I am replacing two windors (rear door windows) and started to disassemble the door interrior and saw the remnants of a rubber seal around the part of the window frame that comes off. there was very little of this material left, but it appears that it was a cushion around the removable metal wandow frame so it wasn't direct to metal with the door itself.
Any help is greatly appreciated!!!
