Having had a few Studes since 1957 I never had to replace a fuel pump. Now on a 1960 Lark wagon I need a new fuel pump. HOW do you get it into block???? I have been fighting it on and off for 5 days. The engine is a 169 CID. I am about to put an electric on it. Can anyone help??? also is there a plate available to cover the opening with ?? Thanks, Hal W
1960 fuel pump installation
It should not be that hard really. Since the angle is bad to get good leverage to push it in compressing the Diaphragm spring. You could install temporary longer bolts to "pull it in" if you do not have enough strength to do it. Then just replace them one at a time with the correct short bolts.StudeRich
Originally posted by hal watson View Postalso is there a plate available to cover the opening with ?? Thanks, Hal W
Cover plate.... for 6 and 8 cylinder applications.sigpic
55 President Deluxe
64 Commander
66 Cruiser
37 Oldsmobile F37 4 Door
I just went through this installing a fuel pump on a 1960 Hawk. Same problem. At the
suggestion of another member, I bumped the starter
a couple of times to rotate the cam lobe, and finally got it where it went it without too much difficulty.
Joe D.
Originally posted by hal watson View Post... is there a plate available to cover the opening with ??Brad Johnson,
'56 Sky Hawk in process
