I found a few seals on trannys One which was a very good deal that comes with a bunch of extra stuff, but it's a long tail out of a lark, the other is a T86 that came out of a 53 commander, seems like a good deal but doesn't with all the stuff that the other one does. mostly wondering if I bought a long tail trans could I swap out tail shafts so I wouldn't have to fight my drive shaft. Having a just that part shipped would be easier and cheaper than shippng a whole trans. Figure this would be easy to answer for most of you but I really wasn't sure.
Can you swap out tail shafts, on a T86
Shortening a shaft is cake. Probably less than $60. I've had complete driveshafts fabricated when I've supplied the yokes for less than $100.
I've put a long tail with overdrive in a '52 Champion and a short tail in a '63 Cruiser. Just verify your solenoid voltage and have a local machine shop fit an appropriate drive shaft.Brad Johnson,
'56 Sky Hawk in process
Originally posted by rockne10 View PostShortening a shaft is cake. Probably less than $60. I've had complete driveshafts fabricated when I've supplied the yokes for less than $100.
Older solenoids are 6V, newer are 12V. Get the wrong one and it might work but will fail sooner or later. Probably sooner. Just get one to match your car.
Originally posted by nvonada View PostOlder solenoids are 6V, newer are 12V. Get the wrong one and it might work but will fail sooner or later. Probably sooner. Just get one to match your car.
Originally posted by GThawkwind View PostOIh yeah, I get what he meant now. All the wiring is gutted out of my car so'm starting fresh with a 12 volt system.
Jerry...
I have a low mileage '63 Lark OD t86 and a high mileage OD Speedster T86. The speedster is under restore. I was told in another post that I can transfer the innards of the low mileage long tail OD directly to the short tail Speedster OD Case keeping the short case main shaft. And, use the low mileage T86 now with the case only from the high mileage transmission.
Do you agree?
Merlin
The short answer is yes, however there are several parts that do not interchange that are only slightly different so it's easy to get in trouble. Just because a trans is higher mileage does not mean it's in better condition. Remove the cover and inspect the low-reverse slider for chipped or worn teeth. If there is no dirt or rust and there is some lubricant so the bearings aren't dry, the trans section should be OK. In the OD the sun gear needs to be inspected. Remove as per manual and make sure the three gears are tight. Jerry Kurtz
Thanks Jerry... that reads a definite maybe. The Lark only has 23,000 miles on and the transmission is tight. The Speedster could have been to the moon and back. I'm always game for an adventure so in a month or so I'll open them up and see what happens.
I just went through this with a broken long shaft O/D transmission and a 56 T-86. The inside parts matched up and worked perfectly, but these were overdrive transmissions and the tail shaft is two pieces. I'm not sure about the non-overdrive transmissions.Jamie McLeod
Hope Mills, NC
1963 Lark "Ugly Betty"
1958 Commander "Christine"
1964 Wagonaire "Louise"
1955 Commander Sedan
1964 Champ
1960 Lark
