Hey folks, I know we have talked these things to death regarding hard starting, vapor lock, leaking, effects of ethanol, etc. I've given it a lot of thought and while I have been tied up with some long overdue home maintenance projects...I thought I would try a little experiment with the carb on my 1955 E-5 185CI truck engine. I have, for a long time, had difficulty with the truck having to crank over for a long time before starting after it sat for a day or two.
We have discussed, at length, about the modern gas boiling out due to heat retention after shutting down a warm engine. My engine will fire right up quickly if you pour a small amount of gas down the carb. A couple of days ago, I "primed" the carb in this manner and fired the engine up. Once it was running smoothly, I shut it down before it could build much heat. Under this scenario, the carburetor reservoir/bowl should be full to its float regulated level.
Today, I went out to the man cave and removed the top of the carburetor only to find it nearly dry. I can only conclude that the gas is either evaporating at ambient temperature, leaking through the casting, or siphoning down to the fuel pump. I am hesitant to install an electric "priming" pump, just because I don't want to (at this time). Instead, I have one of those old "stand-alone" (as opposed to built into the fuel pump) carter glass bowl type fuel filters. It is "period-correct" for my truck, so I am thinking about installing it at the carburetor inlet.
My thinking is that the bowl will give it a closer back-up reservoir of fuel, and move the fuel line from the fuel pump a few more inches away from the heat of the engine. Any comments or experiences from others welcome.
