After getting the new motor to run pretty smooth (per previous threads) I figured it was high time that I try out the new tranny... WRONG!
Clutch does not disengage. When I go to shift into gear the car wants to move with the clutch pedal fully depressed. Of course, I did not attempt to force the car into gear. I took the clutch adjustment rod through it's full range to no avail.
Is there anything else I can try before pulling the tranny?
Details:
Details:
- The tranny is a Keisler-modified Tremec T45 5-speed (think cross between a T5 and 3550).
- Clutch is stock Studebaker with new pressure plate, disk, t/o bearing.
- Dan Giblin adapter kit used to connect the two.
- Everything seemed to go together fine.
