I removed the steering wheel and slide the steering column off the shaft on a 64 lark with 4 speed.
What should I do to clean it up before painting and reinstallation? The plastic turn signal piece seems OK. There is a greasy material over the top section that has goldish speckles in it (could be metallic?)
How do I restore this column? Should I remove all that grease and regrease? Is there something to spray to clean this up? What grease should I use?
Sorry for all the questions but I never done one of these before. Any thoughts would be appreciated. Thanks much.
