Hello all,
I have a GT Hawk of 1964 with a manual 3-speed gearbox with overdrive.
Since a couple of days the transmission is grinding when I want to move him in 1st gear or reverse. I have to be more specific here, when I'm driving and slow down, keep the clutch pushed and move him in 1st or reverse there is no problem. But when I first releases the clutch, next pushes the clutch again and bring him to 1st gear I hear the grinding.
Some history which may help to determine the problem:
When I bought the car in September,2012 it happened it was quite difficult to change gear from 1st to 2nd.
Back in April I had once the situation where the transmission was locked on 2nd. Some searching explained to me that the 2 bars going from the steering bar to the transmission needed to be readjusted. I did that and indeed since then the transmission was functioning smoothly. Because I want to bring the car to perfect condition step by step I decided a couple of weeks ago to change the oil in the gearbox. Also to make sure there is still enough oil in it. I used a mineral transmission oil SAE-80 as stated in the shop manual.
For a couple of weeks the car ran fine, but since last weekend he started to grind when moving into 1st gear and when the clutch is released between coming to a full stop and actually moving into 1st. I tried to re-adjust the bars again but that didn't help.
Is there somebody who can help me with this one? I hope the transmission is not gone, and to be honnest I don't think so. Otherwise I would expect more indications of problems.
Thanks in advance, Guido
