View Full Version : backup lights on 62 hawk
Gordy911
09-02-2007, 07:59 PM
well i should have known when I took the lenses off the backup lights and there were no bulbs that there was more issues than bulbs.
Anyone know where the backup light switch is located sounds like it is bad as the lights are on all the time even in park etc. also noticed when checking the steering column that I have fluid leaking from under the steering box its power steering fluid and is steady dripping so not sure where or what is making it leak any suggestions would be great.
62 GT Hawk
84 vette
31 Ford Pickup
09-03-2007, 04:41 PM
The backup light switch is also the neutral switch to allow starting ONLY in Neutral and Park, it is located on the right side of the steering column under the dash.
IF the car has the correct Bendix type power steering that all unaltered 1962 and on Hawks have, the oil dripping from under the steering gear must be actually coming from a leaking P/S Control Valve which is connected to the pitman arm off of the steering gear. Repair kits to repair the Valve are available at all of us Studebaker Vendors at studebakervendors.com
When looking for the source of a leak, always go to the HIGHEST point that is wet to find the actual SOURCE, rather than where it is leaving the car for the ground!
Studebakers Northwest
Ferndale, WA
Gordy911
09-04-2007, 05:51 PM
Is this a big job or little job getting it off and apart for repair?
62 GT Hawk
84 vette
31 Ford Pickup
09-06-2007, 01:25 AM
It is an easy job to remove the (2) screws holding it to the steering column, it cannot be repaired, most likely has a broken ball on the tripper lever. But the Studebaker Shop Manual describes the installation, which requires the correct positioning of the shifter to prevent breaking the ball end.
I actually have a new NOS one running on ebay right now! :)
It's here:
http://tinyurl.com/2s66r9
Ferndale, WA
Gordy911
09-07-2007, 07:24 PM
well I bid on the new one so if I win it I may have to purchase some expertise to put it in without wrecking it.
62 GT Hawk
84 vette
31 Ford Pickup
