I recently bought a 57 golden hawk with a stuck motor. Removed motor and put it in tank to soak.
Results 4 pistons are questionable with top ring corrosion.
Cylinder walls taper between 3-5 thousands. Hone or bore ?? Big price differnce.
Cam worn but might be OK. Solid lifter are almost all the time need replaced?? Whats with puttng them back in order can the holes for the lifters be honed or cleaned up??
Crank has to be turned .0010-.0010...Expected
Heads need couple new valves and maybe seats. replace with stainless??? pricey
I want to do it right but I have a budget.. Gasket set expensive as is pistons.
Anyone have a source for used pistons or any reasonable prices on gasket set? Wheres the best place to go.
Do you bore or hone cylinders? Your comments and help are appreciated
Thanks Rick
Thanks Rick
