Studebaker engine number
Yes you are missing something, that is the Casting number, they are all the same because it is raised in the mold that created the block.
Your Engine Serial Number is on the other side, the drivers side, STAMPED into the flat machined pad.
Remember "I" 's are Ones.
It appears that your Climitizer Heating and Defrosting System is inoperative.
The water manifold is plugged and only one heater hose coming from the core or Temp. Control Valve.Last edited by StudeRich; 07-05-2013, 12:49 PM.StudeRich
The year is 1963. The 'V' means V8. The blocks were the same for 259's and 289's. The cranks had a different stroke. If it was a 63S, it's a 1963 six cylinder.Tom - Bradenton, FL
David this is my build sheet for my Daytona. If you look at the serial number, it starts with 64V. It means nothing more than it's a 1964 V8 powered car. In '64, the engine numbers were slightly different. Mine was PK328. In '64 they didn't have individual engine serial numbers (so I've been told). The replacement engine I bought was PK326 out of a '64 Cruiser. That 64V should also be on the cowl tag for the body shell (mine is 64V - J8). Yours should start be 64V - L8? I can't remember what the convertible code is.
Tom - Bradenton, FL
Welcome to the SDC and to the SDC Forum Smitty!
At the bottom of the V8 Engine Number Listings it explains the 1964 Engine Numbering (Date Coding) System.
All Blocks that were ASSEMBLED each day had the same Date Code. Yours (VK310) is a Oct 10, 1963 "259" Engine for a 1964 CAR.
The Cast Date Code is at the Rear near the Dist.
When they were Assembled is when it was determined which Blocks were scheduled to get a 289 Crankshaft and Pistons and which would get 259 Crankshafts and Pistons and marked "V", "P" or a Truck Engine Code.
It is very important to know that Studebaker did not make the Clutch Housings and Converter Housings with centered identical Mounting to the Block, they were individually "Dial Indicated" to each Crankshaft Centerline.
Since this Truck should have a Truck Clutch Housing and Transmission to Mount it to the Truck Frame, you need to know IF it has been Dialed-In, or do so per the Studebaker Shop Manual and some "Tricks" (: "Procedures") people here use to make it easier.Last edited by StudeRich; 04-27-2021, 11:29 AM.StudeRich
Originally posted by 51r1 View PostTHANKS VERY MUCH Im looking for a late 289 engine It would appear this is not the one for meStudeRich
Originally posted by 51r1 View PostWell my quest rolls on-- I was told about a 64 Studebaker yesterday for sale-- Its is cheep, so i went to look at it. It was suppose to be a 289. It wasn't , it was a 259 engine with code VCD406 So my quest is still thereStudeRich
-Dwight
