I am trying to rebuild the brakes on my 48 M-5. I found the wheel kits at SI but mine are so rusted that the cups and rubber won't even move in mine. Anybody know of any wheel cylinders to fit the truck. I at least need the fronts. Thanks Tom
Wheel cylinders for a 48 M-5
The New Wheel Cylinders are only available for 1949 "R" Trucks forward, to most others up to 1964.
Unless some very old stock stashed away in a deceased person's closet is discovered, you will be limited to sleeving the old ones unless you update the entire Brake System.StudeRich
This could be your golden opportunity to swap to late model V-8 or late model Champ front brakes.
The Champs should be a bolt on from the backing plates out. The V-8's require that you bolt up the 4 holes that match your spindles, and re-drill the other 2 holes. Either way it greatly improves the braking.
You should be able to adapt a grease fitting to the cylinder and push at least one piston out with a grease gun.1936 Dictator
1950 Champion Regal 4 dr parts car
1953 Commander Regal HT
1953 2R5 Pickup
1947 M16 Truck
1960 Lark VIII Convertible
1960 Champ 5E7 step side short box
1962 Champ 7E5 no box
1962 GT Hawk
1963 Lark VI 4 dr
1963 GT Hawk R2
1964 Daytona Convertible
1964 Commander Wagonaire
“America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.” ~ Abraham Lincoln
