In '08 I bought a Turner dual M/C kit and everything else to go through my braking system from Stephen Allen's. As these projects sometimes go, I'm just now doing the job. I am trying to get this car back on the road this summer after sitting neglected since about 1998. I have already reconditioned all 4 brakes, new hoses, and I have new lines to run even though the stock lines look really good.
Following the instructions, I had no problems removing the old M/C (it's always nice how all the bolts are coated with oil/grease for easy removal!) and lines. I installed the bracket. The short brake pedal brace bracket furnished by Turner was way to long. Instructions say that can be a problem on some models, and to modify either the new or old bracket. I decided it was easier to modify the original bracket, so I did, and got it all bolted up.
Now comes time to install the M/C. I bought the one suggested on the supplied instructions from Carquest, cross-referenced to the Wagner part number F 49275, Carquest # E56193.
The end of the M/C strikes the brace that goes from the frame to the edge of the body so it won't go into position.
Have any of you encountered this problem before? Is there a yet-shorter M/C I can use? I e-mailed Mr. Turner, but of course now that I'm going on this if I can figure it out now I'd like to.
My project is a '60 Lark Regal 4-door station wagon with a V8 and auto trans.
Pictures are attached for your reference.
Thanks,
Michael
Thanks,
Michael
