On my 1950 2R5, I was somewhat surprised to find the gas tank pressurized when I took off the cap to fill up. The weather is now hot. The cap I have seems to vent inward but not outward. Is that correct?
gas cap and venting
Tags: None
It has to vent both ways. I had that problem and it sucked my tank in. On the side of the road I remembered StudeRich's advice and drove a spike through the middle of it. That vented it both ways and I haven't had a problem since. Good luck.Dave Warren (Perry Mason by day, Perry Como by night)
Originally posted by Commander Eddie View PostHmmm. I'll just add to this thread. I just bought a new chrome gas cap for my 61 Champ. I did not think to ask if it vented. Are all gas caps made to vent? Should I check mine? Is there a way to tell by looking if it does, or does not vent?Skip Lackie
This Stant 10640 is vented and correct for Studebakers that have a Gas Door (Cover). Or 10491 Locking, press-on.
http://ww2.stant.com/modules/partLoc...m.cfm?id=10640
These are also sold as #11640 when "Carded".
_______________________________________________________________
This 10623 Gas Cap is for the exposed installations, i.e. Pickups, but will also work inside the Gas Door type Models.
However I have found that in tight areas like Avanti or '59-'61 Larks it is a bit difficult to turn them.
These are the ONLY correct OEM replacement Caps that are correct for our Cars, that I have ever bought.
They are sold under the Car Quest, NAPA, Gates, and Stant Carded, bubble pack #11623 (for 10623)
As you will see on their Website.Last edited by StudeRich; 06-28-2013, 03:23 PM.StudeRich
Since my cap looked nice, figuring I really had nothing to loose, I drilled a 1/8" hole in the center check valve plate. Vents both ways now and looks the same on the outside. When I need a new one I will buy the correct part.
Thanks for the info.
Norm
You nailed it- Hit the nail on the head
very good jimmijimOriginally posted by warrlaw1 View PostIt has to vent both ways. I had that problem and it sucked my tank in. On the side of the road I remembered StudeRich's advice and drove a spike through the middle of it. That vented it both ways and I haven't had a problem since. Good luck.sigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
Has anyone retrofitted a modern non-vented evaporative control to a Studebaker? With a vented system, there will always be a loss of fumes into the storage area. Not a problem in a free standing garage. This could be a problem in an attached garage especially in warmer climates. This is one of the reasons attached garages were not permitted in some areas years ago.
Jerry
Okay. I checked the new chrome gas cap I just bought for my Champ truck and it appears to be vented. On the underside is a blue plastic piece with a hole in the center of it. I am not sure where it vents through, but it certainly looks like that is what it is designed to do. It has been hot here the last few days and I have had no problem with a vacuum forming in my gas tank so I believe the cap is doing it's job.
I constantly remind myself why this forum is so useful. These seemingly esoteric things up and you find yourself learning something you never even thought about. Keep the great questions coming. I'm a sponge.Ed Sallia
Dundee, OR
Sol Lucet Omnibus
Commander Eddie, the fuel pump will cause a non-vented cap to suck in the fuel tank. You won't notice it on the road until it runs out of gas. On mine, the bottom of the tank rose to the point the sender unit was showing fuel in the tank, but there was none. When I vented the cap and refueled, luckily the tank popped back out. It was a restored tank (Gas Tank Renu). An original might not pop back.Dave Warren (Perry Mason by day, Perry Como by night)
Originally posted by warrlaw1 View PostCommander Eddie, the fuel pump will cause a non-vented cap to suck in the fuel tank. You won't notice it on the road until it runs out of gas. On mine, the bottom of the tank rose to the point the sender unit was showing fuel in the tank, but there was none. When I vented the cap and refueled, luckily the tank popped back out. It was a restored tank (Gas Tank Renu). An original might not pop back.Ed Sallia
Dundee, OR
Sol Lucet Omnibus
It's the original tank that has been coated and baked inside and out. Without the coating, the old metal would have been less able to return to its original form. Metal gets tired.Dave Warren (Perry Mason by day, Perry Como by night)
