I have the pcv fitting to replace the draft tube. The only intake vacuum port I see is the one where PB booster and dash vacuum gauge line goes. Can I just put a T fitting on top and run the pcv and vacuum gauge
from that point? Is there a modern check valve sold at Napa or ? that will work in the line from block to T fitting?
Thanks !
Thanks !
