I installed the Ross box on my 74 today and filled it with 80/90 lube as Dan Booth recommended.
It has had the lower shaft (Sector??) seal replaced. However it immediately started leaking past the upper (Steering??) shaft seal.
I talked to Dan Booth - Nostalgic Motors about getting one and he said he's never seen one leak and doesn't (never had) them anyway. He said he thought they could be the same as the Studebaker Avanti 63/64 but not sure. I've looked at most of our suppliers that have websites and cannot find anything that would seem like it will work nor any Jeep suppliers either.
So I either need a source from the assemblage or let the box operate below the level of the seal which it will anyway.
The box was essentially dry when I got the car and I could see it was leaking past the lower seal which is new and not leaking now. I may to try shimming the current seal if there is no other answer.
The seal in it's mounting plate.
As always, thanks in advance.
Bob
Bob
