Hello, I changed the spark plugs on my '53 Studebaker 6 Cyl. but now for some reason the engine won't fully start. I think for some reason the engine isn't getting the fuel it needs....any ideas on why? (I think it may have to do with the fuel pump, although I do need a carb. rebuild since it's leaking) - Kelii
Starting Issues
Fuel System: Starting Issues
Sure she may have 85hp, sure she may not be the most attractive or fastest thing out there, but she is the best car that represents me- 1953 Studebaker Champion SedanTags: None
If all you did was change the spark plugs, it sounds like you've upset the firing order by placing some of the wires on the wrong plugs.
You say it won't "fully start," which implies it is trying to start, so some of the wires are on the correct plugs and some aren't. Check the firing order and make sure each wires is on "its" plug. BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
I followed the order of the firing order and distributor given to me by the forum members, and even back to the wrong order before...neither would work. The starter engages and the engine turns over about once or twice then stops...Sure she may have 85hp, sure she may not be the most attractive or fastest thing out there, but she is the best car that represents me- 1953 Studebaker Champion Sedan
Kelli: OK, let's start from scratch.
First Question: Did you remove the distributor from the engine?
Or: Did you loosen the distributor hold-down bolt and rotate the distributor a little in either direction, without removing it? BP
I did not touch the distributor, I just repositioned the wires according to how they are supposed to fire on the engine and replaced the spark plugs.Sure she may have 85hp, sure she may not be the most attractive or fastest thing out there, but she is the best car that represents me- 1953 Studebaker Champion Sedan
starting
Originally posted by 57Kelii View PostHello, I changed the spark plugs on my '53 Studebaker 6 Cyl. but now for some reason the engine won't fully start. I think for some reason the engine isn't getting the fuel it needs....any ideas on why? (I think it may have to do with the fuel pump, although I do need a carb. rebuild since it's leaking) - Kelii
Originally posted by altair View PostStart from scratch, remove the distributor cap and rotate the engine observing the direction of the rotor and stop on IGN (also top dead centre) and note where the rotor is pointing, that is #1 firing, then following the direction of the rotor next is #5,3,6,2,4. Does the engine fire once or twice or just turn over once or twice? Was it running OK before with out any issues? DaveSure she may have 85hp, sure she may not be the most attractive or fastest thing out there, but she is the best car that represents me- 1953 Studebaker Champion Sedan
This may offer some help:
Information borrowed from Bob Johnstone's Studebaker website:
In the middle of MinneSTUDEa.
Kelli, So far, there have been some good suggestions regarding your problem. However, keep in mind that few doctors would attempt to examine and diagnose a patient by computer, phone, or any other remote communication method outside of a hands on up close examination. My question would be why you started by changing the plugs in the first place? I'm not being critical, because "Plugs" being worn and fouled are often the culprit in poor running engines. However, your problem could also be something as simple as the tiny rub block on your points inside the distributor wearing down and causing the point gap to lose its optimum setting. This tiny little gap can really upset the smooth operation of an engine. Another thing to consider is that some past owner could have improperly installed the distributor and then arranged the plug wires to make it run correctly. If that is your case (and believe me, I have seen it done), orienting the wires to the manual specs will never work if the distributor body is installed out of position. I have an engine that has a distributor 180 degrees out of phase. However, with the wires arranged so that the firing order is still correct, it runs just fine.
These engines are very simple, but, they do require a bit of study and understanding of the sequence of events for them to run properly. As I have said before, they are a tinkerer's dream, but for those who expect to run them a hundred thousand miles between tune-ups like a modern car...they are a nightmare. My thinking is that you are in a "car crazy" part of the country with some fine folks knowledgeable about the operation and quirks of Studebaker engines. It would be good if you could get a fellow local SDC member to mentor you and assist in diagnosing and solving your problem.
Problem is...California is larger than lots of countries, let alone "states" and some of us in other parts of the country have difficulty wrapping our brains around the concept of the distance between "Local" SDC members in a state as large as yours.
When I change spark plugs, I change them one at the time and only remove one wire at the time. In your situation, if your distributor is installed correctly, placing the wires in the order specified by the manual should provide good, smooth running, ....as long as the plug gap is correct, plug wires are good, the distributor cap is good, the rotor is good, points are good, point gap is good, condenser is good, coil primary and secondary circuits are good, and the carburetor is working properly. Just to mention a few other tiny items that make a big impact.
I'm not trying to be a smart-Alec (family friendly expression), but all these things have to be addressed. Good luck with the problem solving, and let us know what resolves the problem.John Clary
So, if I read this correctly, you're saying the wires were out of order before you started? How many were out of order? It seems to me that on a 6 cylinder, even if you only had two out of place, the whole thing would run horribly. Can you post the order that the plugs were in at the start of this project?'63 Lark Custom, 259 v8, auto, child seat
Well I wanted to change the plugs because the order was wrong and I wanted the engine to perform better. I also needed to learn more about vintage cars....I don't really have a family to help me on this...and every time I took it to a mechanic, they'd not really let me watch since they are so busy...so I have to try and study from books, but hands on training is easier. Working on a 60 year old car not knowing how everything properly works makes it hard for me.Sure she may have 85hp, sure she may not be the most attractive or fastest thing out there, but she is the best car that represents me- 1953 Studebaker Champion Sedan
Originally posted by JimC View PostSo, if I read this correctly, you're saying the wires were out of order before you started? How many were out of order? It seems to me that on a 6 cylinder, even if you only had two out of place, the whole thing would run horribly. Can you post the order that the plugs were in at the start of this project?Sure she may have 85hp, sure she may not be the most attractive or fastest thing out there, but she is the best car that represents me- 1953 Studebaker Champion Sedan
Originally posted by 57Kelii View PostWell I wanted to change the plugs because the order was wrong and I wanted the engine to perform better. I also needed to learn more about vintage cars....I don't really have a family to help me on this...and every time I took it to a mechanic, they'd not really let me watch since they are so busy...so I have to try and study from books, but hands on training is easier. Working on a 60 year old car not knowing how everything properly works makes it hard for me.
Then some of us used to know...but forgot...
It's a never ending process...John Clary
Originally posted by 57Kelii View PostWhat do you mean by rotate the engine? The car doesn't fire, but turns over. Before, the car was running but wasn't idling consistently due to the fact the order was not correct. A day before at a car show, a mechanic who worked on ww2 vehicles at a museum adjusted the carburetor to idle a bit better.
