Anyone using these on an Avanti? The offset is the same as a factory wheel rim at 3.500". So that should give the proper clearance and car stance. Would the factory lug bolts be to short for the hole depths? What about factory disc caliber clearance? Sale ends this week but hesitant to order at the moment.
Avanti Mag Wheels
Haven't used those so couldn't address your fitment question. As to fasteners, they make the proper lug nuts to fit them on OEM studs.
You didn't ask but those probably wouldn't be my first choice on an Avanti - seen 'em on too many Chevelles. JMHO, if I were buying new aluminum wheels, I'd certainly consider stepping up to 16" or 17". Basically the same price and more choices both in wheels and tires.
jack vinesPackardV8
They're 15X6", which means they're 7" wide at the bead seat and with a 3.5" backspace they have zero offset. The Magnum 500 rims used on the Avanti II's have a +15mm offset to keep the tire satisfactorily under the fender. Granted 15mm (5/8") isn't much but depending on your tire choice, could make a big difference.64 GT Hawk (K7)
1970 Avanti (R3)
jack vinesPackardV8
