I don't have a lot of info yet because of not driving it a whole lot since buying the 63 Lark but when I get to about 55 I notice a vibration in the gas pedal and a humming noise as well. Without much info on this does anyone have a guess? I am leaning towards maybe loose or warn out motor mounts since I am only feeling it in the pedal. I feel like if it was tires out of balance or something along those lines I would feel it in the steering wheel. I hope to get it out on the road this weekend to try to get more information on the matter. Thanks
Vibration in gas pedal at 55mph
Originally posted by Ensane13 View PostI don't have a lot of info yet because of not driving it a whole lot since buying the 63 Lark but when I get to about 55 I notirce a vibration in the gas pedal and a humming noise as well. Without much info on this does anyone have a guess? I am leaning towards maybe loose or warn out motor mounts since I am only feeling it in the pedal. I feel like if it was tires out of balance or something along those lines I would feel it in the steering wheel. I hope to get it out on the road this weekend to try to get more information on the matter. Thanks
If the engine mounts check out OK, you can look further by checking your U=joints for wear or lack of lubrication. Another area that gets a little more complicated is if there was some past work done that required changing or removing the engine or bellhousing. For those who are not familiar with Studebaker specific quirks...those components are individually matched together (dial indicated/indexed) and will cause the symptoms you describe.
Slight vibrations can be puzzling and difficult to diagnose because of how the "harmonics" manifest themselves at various speeds. There is an entire engineering science dedicated to the subject. Several years ago, studies in harmonics and vibration resulted in a revolution in the design of tooth configuration for saw blades. It heralded a whole new round of competition among manufactures marketing them with advertising campaigns such as "New Vari-Tooth Design"...or "Mix-Tooth"...etc. It got so crazy that copyright lawsuits were threatened.
One other area to look at would be a slight miss-fire under electrical load in your ignition system. If your distributor cap has a bit of carbon build up that allows "carbon tracking," under certain conditions, you can experience an erratic condition that causes a slight vibration that will drive you nuts until you discover the problem. A small crack in the distributor cap or slight carbon tracking may operate almost normal until it gets bad enough to cause an obvious miss-fire. Eventually, it will cause the engine not to run.John Clary
