Wow. I now have working windows thanks to Jeff and am looking at getting working wipers so my heap is coming together. Anyhow I got this wiper motor when I got the car, it is not stock and is 12 volt, but bolts up like the factory unit. It is a Prestolite and the number on the case is "PMA 4002". I took the motor apart and the brushes and armature look good so I need to find a plug to wire into my car with a switch. This motor has a weird 4 prong plug having 2 male and 2 female ends. Being a Prestolite or Autolite I might assume Ford, but I do not know. Also where can I find wiper arms?
Need to I.D. this wiper motor and plug.
Go to your local FLAPS, Carquest, NAPA, whatever and tell them you want to look at a catalog of plugs. These are common enough they may have them in stock; can certainly order one. Heater and defroster motors, as well as distributors used identical half plugs. My local Carquest has these hanging on pegboard just inside their door. If necessary, you could mate two of those side by side.Brad Johnson,
'56 Sky Hawk in process
I am pretty sure it is a '63-'64 Hawk 1351452 4 wire Prestolite/Autolite wiper motor.
With wiring changes they fit all '53 to '64 C & K and all '53 to '60 Sedans and Wagons, no Fords.
A check of the wiring diagrams on studebakerpartsonline and Bob Johnstone's site will be necessary to figure out how to re-wire it from 4 to 3 wire or to the correct switch.StudeRich
Originally posted by StudeRich View PostI am pretty sure it is a '63-'64 Hawk 1351452 4 wire Prestolite/Autolite wiper motor.
A check of the wiring diagrams on studebakerpartsonline and Bob Johnstone's site will be necessary to figure out how to re-wire it from 4 to 3 wire or to the correct switch.Alex Nelsen, certified Studebaker nut.
Lizella, GA
Originally posted by Studebakercenteroforegon View Post'63 - '66 Lark types also had the 4 wire plug Prestolite wiper motors.
Of course as you know the Cowl Vent Climitizer Systems have a totally different Wiper Motor however.StudeRich
