Here is what I did for the Avanti
Steering Gear - As per the manual SAE 90 GL1 gear oil as used in the little grey Ford tractors - got it at TSC on the US side in a 2 gallon jug
Transmission - Ford Type F ATF
Power steering - Ford Type F ATF
Differential - Red line synthetic 75W90 and a limited slip clutch additive.
Plans for the 47 Champion
Steering gear - Manual talks about a special lubricant per Ross gear - I am going to use John Deere corn head grease as I use in a lot of tractor steering gears
Transmission with OD - I am thinking of using the SAE 90 GL 1 left from the Avanti steering gear or even 15W40 Rotella as 40 weight is an option
Differential - manual talks about SAE 90 Hypoid gear lubricant - I plan to use 80W90 GL5 oil as that is probably what is the replacement for the original.
Make sense to all the gurus out there?
Thanks
Neil
Thanks
Neil
