While at a car show a person told me of a dual mechanical/electric fuel pump arrangement that is said to make a slow starting car fire up quicker without flooding and stater grinds far less. The electronic pump is used ONLY for starting and is controlled by a switch on the dash. It is turned on for a moment, prior to ignition, whereupon the car is started. It is as if the electric pump is a primer and is in the off position after car starts.. He was very pleased with it. Has any one heard of this and what do you think?. Ken, Deltaville, Va
Dual mechanical-electric fuel pump
No could find but they may exist. Seems like the worst of both worlds, a mechanical pump that doesn't look original and an electric pump mounted up by the engine in a position that would make it difficult to draw fuel and probably not solve a vapor lock issue.
If they gave me one, I sell it and put an electric back by the tank and keep the mechanical, if I wanted the look. In the real world, I'd just put in the electric pump like I do on all my cars and block off the pump access.
Bob
I think that it's most likely a miscommunication or a misunderstanding on the part of the car show person who talked to Ken. He's probably talking about an electric pump used in conjunction with the mechanical one to assist the mechanical pump, like many of us have done on our cars. Maybe his mechanic installed it and he did not fully understand the explanation from the mechanic.
The electric pump is usually mounted back by the gas tank and the mechanical pump sucks gas through the electric one when the electric one is turned off. When cold starting is required, or when vapor lock threatens, the driver turns on the electric pump and positively feeds the mechanical pump. Works great both for cold starts and vapor lock prevention.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by RadioRoy View PostI think that it's most likely a miscommunication or a misunderstanding on the part of the car show person who talked to Ken. He's probably talking about an electric pump used in conjunction with the mechanical one to assist the mechanical pump, like many of us have done on our cars. Maybe his mechanic installed it and he did not fully understand the explanation from the mechanic .
Originally posted by Son O Lark View PostThat's the way I understood it. Two separate pumps.
The reason I know that is, there is no way a "Universal" Mechanical Pump could fit hundreds of Engines, certainly NOT a Studebaker.
As usual everyone has their own reasons for preferring different things, count me in the: "If it isn't broke, LEAVE IT ALONE Group".
This all started with a comment that my R2 grinds too long before it starts and you have to be careful to avoid flooding the engine. In any case it sound like an electric pump, energized for a few seconds before starting engine might help. A friend with an R2 has the same issue. A question though, will the electric pump (installed at he tank) push gas through the mechanical pump up to the carburetor without damaging anything? Ken, Deltaville, Va
Originally posted by ken-renda View Post, will the electric pump (installed at he tank) push gas through the mechanical pump up to the carburetor without damaging anything? Ken, Deltaville, Va64 GT Hawk (K7)
1970 Avanti (R3)
Originally posted by ken-renda View PostThis all started with a comment that my R2 grinds too long before it starts and you have to be careful to avoid flooding the engine. In any case it sound like an electric pump, energized for a few seconds before starting engine might help. A friend with an R2 has the same issue. A question though, will the electric pump (installed at he tank) push gas through the mechanical pump up to the carburetor without damaging anything? Ken, Deltaville, Va
Try a NC Hobbs switch (pressure activated switch) mounted at the carb inlet line set for 5psi. Gas line out of the tank to a T with one outlet to the electric pump the other bypassing through a check valve reconnecting on the pressure side of the electric pump with a T, then continuing to the engine as normal. The Hobbs switch is wired to the key switch and the electric pump. In operation, the ignition is turned on to start. If there is 5psi pressure remaining in the fuel line the electric pump doesn't engage. If, as it would be normally, there isn't 5psi, the electric pump is engaged until the mechanical pump can maintain 5psi. The mechanical switch doesn't have to pull through the pump as it bypasses around it. The electric pump doesn't pump back through the bypass because of the check valve.Jim
Originally posted by SN-60 View PostAt what position are You keeping the throttle at when You go to start that hot R2?
Given that the quality of gasoline has changed, and not for the better as far as our cars are concerned, I think the only logical solution is to go to a full-time electric pump, and block off the mechanical. You could also install a momentary switch in the line to allow you to manually shut off the fuel pump before parking the car in a situation where percolation after a hot soak might be an issue. Shut the fuel pump down about a quarter-minute before stopping the engine, and less fuel will remain in the bowl to cause percolation issues. Hide the switch under the dash, and it also serves as an anti-theft device.
Any full-time electric fuel pump installation should also include a switch and/or relay intended to kill power to the pump if the engine quits, but the ignition remains on. As a safety feature.Gord Richmond, within Weasel range of the Alberta Badlands
