I had never heard about the R 4 engines being "grenade" engines and reading on this forum about rods thrown through the side of
the block, being such "dogs", etc. I never owned one and only drove one back in the mid '60's. One person (don't recall who and I'm not ragging on anyone particular here) said to ask a noted Stude guy about how bad they were about blowing up, etc.
So, I did. This person had no idea where these stories came from. His comment was they must not have been too bad as they ran at Bonneville setting records and ran from three to five mile wide open. I also talked to two other noted Stude R guys that had not heard anything about this either.
I'm not saying none blew up but I need more proof than someone saying they did. Might have come from a few of the "rag on the Studebaker every chance I get" people. I know it's entirely possible one (or more) did but . . .
As for the new 350 crate engines putting out more hp than R engines just doesn't cut it. All you have to do is go to the PSMCDR and see the actual run side by side comparisons. And I'm not referring to just the Wrapper or Tomato. Here are some hp figures put out by the PSMCDR officials using ET, Speed, and weight to figure REAR wheel hp:
Steve Doerschlag's R 1 HP 246 ET 14.46 @ 95.98 (Steve is new to these races and is running TWO cars and will get better every year)
Richard Poe's R 1 HP 247 ET 14.49 @ 95.48 (Richard has had traction and axle problems and should be noted he has turned 13.8? @ 98.??) and I'm not sure if he's ever lost a shootout race! His last year there he was set to get into the 13's but broke an axle.
Chuck Kern's R 2 Avanti HP 295 ET 13.97 @ 101.32
Allen Anderson's R 2 Hawk HP 250 ET 14.76 @ 93.96 (Allen's Hawk weighs over 3800 pounds)
Peter Sant's R 2 Avanti HP 319 ET 13.92 @ 102.26 (Peter's car is really heavy (around 3800+ with driver) as he has AC, extra insulation, etc.
Rich Meadow's R 4 HP 235 ET 14.61 @ 96.13 (with NO traction devises to stop wheel hop. Wonder the rear end stayed in and it didn't blow).
Steve Doerschlag's R 3 Commander HP 302 ET 13.48 @ 102 (This was with the supercharger boost going to zero in third gear, slipping internally)
Tomato R 2 Passed volunteer certification TWICE HP 373 ET 13.09 @ 110.26 (In 2011 it was rated at 408 HP and 113.2 mph due to a strong tail wind on one run which I realize was bogus. A tail wind really helps the Lark as a head wind really hurts it). Due to this the car was picked as one to be "Heavy Teched" in 2012. Passed this also.
Interesting side story. In 2004 there seemed to be some talk that the Studebakers were NOT stock so we volunteered that year to go through the certification process. The quickest it had turned up to that time was 13.4? The day after being certified it turned 13.30 so that stopped the talk for awhile.
Tomato Clone R 3 (also certified!) HP 393 ET 12.68 @ 112.1 (First time on the strip)
Wrapper HP 378 ET 12.66 @ 114.03 It was on a rear wheel dyno several years before this and recorded 365 hp.
I might also mention we have to run 70 series tires as 60's were not available in '63/'64 so the cars able to run 60 series have a definite advantage on 60' times.
The most HP I could find on the 350" engines was 353 (Yenko) and the next best was (Z-28) 319. Rest were well below these.
As for the two fours on the R 4, i realize the extra does not add much to the HP but to say it is so horrible I don't think it is. I ran two R 2 carbs on the 51 for years as I figured they would feed each cylinder better than one four and also figured it would blubber, bog, etc. but it did not.
I experimented on how much gas it used by running along about 40 mph and shut the electric pump off (no mechanical pump) and see how far it would run before running out of gas. The two fours would go almost twice the distance as one four did. I know ithis is not very scientific but think it shows the over carbed theory may be just that to some extent, just a theory.
I also remember Phil Harris and Malcolm Berry had a 289 with two barrel 450 cfm Holley on the dyno once and decided to put on a bigger Edelbrock 600 cfm that made it over carbed for this engine. They found it made MORE HP than it did with the Holley and the formula for this engine said it needed a 375 cfm carb. The dyno operator was surprised that it actually made MORE hp.
Sorry this is so long but I'm all ready to leave for Martin, Michigan, tomorrow for the FAST/FactoryStock race and nothing to do so thought I would research some of this. We may lose every race at Michigan but I'll have a ball just giving them a Stude to run.
Ted
Ted
