This has probably been asked and answered a dozen times sorry. What holds the u-channel in place in a M-5 door? The only clips I see is the U-channel clip half way down on the inside of door, and a small nail/tack at the other end close to the vent window. Is it the inside window frame or do I glue it? Also why so many window run clips. A rubber kit has 20 clips Is that 5 per cat whisker? Thanks Michaelb
M-5 U-Channel
I think the "U" channel in most all Studes is held at each end with a channel clip, and glued--liquid nails works--betwixt.Brad Johnson,
'56 Sky Hawk in process
Originally posted by rockne10 View PostI think the "U" channel in most all Studes is held at each end with a channel clip, and glued--liquid nails works--betwixt.Ed Sallia
Dundee, OR
Sol Lucet Omnibus
