Does anyone make reproduction rubber vent rubber seals for 55-58 Y body sedans? S.I. lists only "U" channels, and it appears that the channels are pop-riveted in place, which will require removing the entire vent assembly. I had to remove both left front and right rear vent assemblies to remove cracked side windows, and the brittle rubber on the rear vent seal was damaged. See page 69 of current on-line S.I. catalog. Any help would be appreciated.
Vent window rubber seals and "U" channels 55-58 Y body sedans
