hello, what is the collective wisdom about rebuilding front calipers? Is there someplace with an exchange deal or is rebuilding the way to go?
rebuild front calipers?
Originally posted by t walgamuth View Posthello, what is the collective wisdom about rebuilding front calipers? Is there someplace with an exchange deal or is rebuilding the way to go?
I found some pitting inn the cyls , I read somewhere about using some stuff called pyro putty, I ended up using a Wurth 2 part epoxy to fill the pitting, sanded it out lightly, and finished it up with a brake cylinder hone..
make sure you lube up everything upon assembly, i used a good quality brake lube from Napa, it was purple,
Watch those x-over lines, they have a bubble flare and a regular flare on each end..
Dave Thiebault sells stainless sleeved rebuilt units on an exchange basis, or send yours in to him to redo.Bez Auto Alchemy
I like rebuilding my own stuff. Dave might be a little different if he's doing them in house.Tom - Bradenton, FL
