I had the vent window post welded on the bottom ,and now I want to tighten the nut on the bottom of the vent window , how much do I turn that nut ,or how tight should it be? Thanks for all your help, Mike Driver's side vent window
How tight do I make the crimp nut on the bottom of vent window? 55 c body
Tags: None
It is intended to be adjustable and, as Rick said, tighten until you think it will stay where you put it without being difficult to open and close.Brad Johnson,
'56 Sky Hawk in process
