I bought a '63 Avanti last fall. 63R-1880. It is an R1 (verified with the production order) The front end has been replaced, I assume , as it has the square headlight surrounds like a '64. It has a sort of oval air filter under the right front fender, with a hole through to the engine bay where obviously intake duct hose was routed somewhere. Do I correctly assume this would be correct for an R2 and the duct would have gone to the supercharger intake? Is there a carburetor bonnet which would allow me to use the under fender air filter, and do away with the underhood air filter housing. I think it would be a cleaner look, since the Avanti air cleaner housing is long gone, and the aftermarket thing on there now is pretty revolting. I was also wondering if the cooler air from under the fender would make the engine happier in hot weather than the engine bay air...
Hopefully all this is clear enough to be understood.
Thanks, Kelly
Thanks, Kelly
