I have my '51 Champion up on jack stands and gave it its first spring-time startup. I could hear a intermittent light clunking sound coming from the rear-end, so put the car in gear, got out for observation. The clunking was coming from the right side and I noticed that the wheel was not turning, but just jumping a couple of inches every 2-3 seconds . Is this normal or am I having an issue with tight brakes or bearings on that side of the car? Possibly another problem? Thanks for the replies.
Possible Rear End problem
Rear Axle: Possible Rear End problem
Dave D.
'51 "Bulletnose" Champion
'59 "Silver Hawk" V8
Smithers, B.C. "Where a Stude in hand is worth two in the bush"Tags: None
The rearend is what is referred to as a "open" rearend as compared to a limited slip or locker design. So to answer your question what your observing is a normal function. The wheel that turns either left or right side will be the wheel with the "looser" brake adjustment.
Originally posted by Champion51 View PostI have my '51 Champion up on jack stands and gave it its first spring-time startup. I could hear a intermittent light clunking sound coming from the rear-end, so put the car in gear, got out for observation. The clunking was coming from the right side and I noticed that the wheel was not turning, but just jumping a couple of inches every 2-3 seconds . Is this normal or am I having an issue with tight brakes or bearings on that side of the car? Possibly another problem? Thanks for the replies.
53 2R6 289 5SpdOD (driver)
57 SH (project)
60 Lark VIII 2dr sd (driver)
