View Full Version : Do I need to replace 1955 fuel sending unit?
DilloCrafter
03-03-2006, 11:59 PM
I'm wondering if I'll need to replace the fuel sending unit that's in my '55 truck, now that I've changed the fuel gauge to the 12v version. It's just a variable resistor in that sending unit, but can it handle 12v, since the one that's in there was part of a 6v system? The gauge was not hooked up when I bought the truck, whose previous owner had converted most everything to 12v. I've bench-tested the fuel sending unit with an ohmmeter and get a range of 0-98 ohms.
It'll save me lots of bucks if I can keep using the old sending unit (by the way, I coated the cork with POR-15 gas tank sealer - I had bought the stuff before looking at the inside of my pristine, rust-free gas tank, so I used it on the sending unit float to "seal" it instead).
Thanks for any replies and opinions, or just plain "Howdy"s.
http://simps.us/studebaker/misc/images/Current_Avacar.gif[/img=left] - DilloCrafter
1955 1/2 Ton Pickup
[i]The Red-Headed Amazon
gordr
03-04-2006, 01:27 AM
http://rocketdillo.com/studebaker/misc/images/Current_Avacar.gif[/img=left] - DilloCrafter
1955 1/2 Ton Pickup
Well, Howdy, then!
I'm pretty certain you will have to change your sending unit, too. I believe the 12 volt sender has a resistance range of about 40-400 ohms versus 10-100 ohms for the 6 volt unit. It WILL be different, though.
The specs on these are kind of hard to find, I think.
If you simply installed a series resistor, the gage might read right at one point in its range.
Seems to me there is a business opportunity for somebody well-versed in integrated circuit design to come up with a little box containing an Op amp and a transistor to sink current. Set it up so the gain of the Op amp could be varied over a wide range, and such a device could be used to operate just about any current-sensitive gage with any variable-resistance sender.
But, for the time being, I'd say the easiest way out is to simply buy a 12 volt sending unit ('56-up Transtar), or maybe a "universal" Stewart-Warner 12 volt sending unit, assuming you used a S-W gage unit.
studegary
03-04-2006, 04:18 PM
I had a spare 12 volt truck sending unit that I threw in when I delivered the last truck that I sold. I then found out how much replacements cost and I now have another 12 volt truck. I guess I am still learning <G>.
DilloCrafter
03-04-2006, 11:43 PM
Thanks for the replies (and the Howdy). Gordon, I can always count on you for electrical help, it is much appreciated. All the 12v universal type sending units I found on the web seem to be the same - 240 ohms empty, 33 ohms full. Here's the cheapest one, at $35.74, including shipping: http://www.performancepartz.com/auto-meter-universal-fuel-level-sending-unit-p-22310.html. I'm going to assume the 12v Stewart Warner gauge is looking for that resistance range (I guess I can test it with a few resistors of different sizes, and a 12v power supply).
Looking at the photo of it (see link above) that universal unit is physically "inverted" compared to the original Studebaker part. Notice that the pivot is at the bottom of the tank. Who knows, maybe it is more accurate.
Or, the best price among our Stude vendors for the correct part is $53.50 at SASCO (not including shipping). So, I'll probably spend the extra $25 and get the Studebaker part, even though it's not correct to put a 12v sending unit in a '55 truck. Seems I won't let myself stray TOO far from original, even with the mild modifications I'm doing to the Red-Headed Amazon.
1955 1/2 Ton Pickup
gordr
03-05-2006, 12:16 AM
1955 1/2 Ton Pickup
If the 12 volt gauge you have installed is a genuine Studebaker gauge, I'd get the correct sending unit from SASCO, because it should work right out of the box with that gauge. If the 12 volt gauge is some kind of aftermarket part, there's no guarantee it will work with ANY sending unit other than the one it was meant to.
The universal sending unit needs to be set up to work in your tank; i.e. the float arm has to be configured the right way so that the arm makes a full excursion from one stop to the other as the fuel level in the tank changes. Given that it could well take several hours of your time to get it right, the extra $20 doesn't look so bad.
DilloCrafter
03-24-2006, 12:31 AM
Update: Although the gauges and wiring are not in my truck yet, I was able to mount a NOS 12v Studebaker (Stewart Warner) fuel gauge in the gauge panel on a bench, attach leads to a 5k ohm potentiometer, and connect it to a 12v power supply (my battery charger, putting out 11.5v). With the potentiometer at 240 ohms, the gauge reads empty, and at around 33 ohms, it slowly creeps up to Full. I rotated the pot until the gauge read exactly at the 1/2 tank mark, disconnected power leads from the potentiometer, and measured 110 ohms. I'm guessing it would read 1/2 tank at a slightly higher resistance if another volt were being put out (such as by an alternator, typically over 12v).
I hope this info will be useful to anyone else in this situation.
Also, I found that Summit Racing has a Stewart Warner fuel sending unit (33 - 240 ohm) that is adjustable. I may have to go ahead and get it since SASCO has a 2 or 3 month wait on their sending units. Otherwise, I would buy from a Stude vendor (hard to beat the $27.95 price for this adjustable sending unit, and at least it is Stewart Warner, same as the NOS gauge).
1955 1/2 Ton Pickup
jjones
03-24-2006, 07:06 PM
Normally I would never recommend J.C. Whitney as I have not had much luck with their crap. However, they sell two adjustable, universal fuel sending units, one for GM vehicles that is a 12-volt, 0-90 ohm unit, and a 240-33 ohms one for "all vehicles with Stewart-Warner guages." Either is $17.99. At that price, it might be worth a try. I have the 0-90 ohm unit in a non-stock gas tank in my M truck, with a GM guage istalled behind the original guage face. It works fine and looks stock.
jj
DilloCrafter
03-24-2006, 10:42 PM
Thanks, JJ. That's a very tempting price.
I'm still inclined to go with this one at Summit, for two reasons
1) It's a Stewart Warner brand gauge, like the original
2) It's pivot point is at the top of the tank, like the original.
All the other universal ones I've seen have the pivot at the bottom of the tank. Not that that's worse or better, it's just that I feel a bit closer to original with the Stewart Warner model seen at this link (http://store.summitracing.com/default.asp?Ntt=stewart%20warner%20fuel%20sending%20unit&searchinresults=false&Ntk=KeywordSearch&DDS=1&N=115&target=egnsearch.asp)
Here's a shot of it:
http://static.summitracing.com/global/images/prod/large/sww-114876_w.jpg
1955 1/2 Ton Pickup
mdelapp
08-25-2006, 05:10 PM
I tried the JC. Whitney site and did not find the unts. do you have a link? I thought for $18 I could get it to just hook up to gauge nd see how it responds when rotated. thanks
Mike D
jj
Mike DeLapp
Barrington, IL
53 Commander Hardtop
08-25-2006, 06:18 PM
jj; here is the current catalog #713J-08, Pg.130, item # RB128-526 (240-33 OHM) $17.99 Adjustable float with arm at the bottom.
[quoteI tried the JC. Whitney site and did not find the unts. do you have a link? I thought for $18 I could get it to just hook up to gauge nd see how it responds when rotated. thanks
Mike D jj[/quote]
Studebakers Northwest
Ferndale, WA
DilloCrafter
08-25-2006, 06:47 PM
I recommend authentic Stewart Warner, since that's who made your gauges.
Here is the link to the one at Summit Racing:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SWW%2D114876&N=700+115&autoview=sku
While the J.C. Whitney sending unit is $10 less, it is configured differently. You need to adjust the overall height, as the potentiometer and pivot point sit at the bottom of the tank.
On the other hand, the Stewart Warner version from Summit Racing is configured the same as the original, with the potentiometer, and thus, the pivot point, at the top of the tank. It is a universal type unit, so you must measure and cut the rod before assembling it. This is the kind I bought, and had no trouble preparing it and installing it in my truck.
1955 1/2 Ton Pickup
Deep in the heart of Texas
jjones
08-25-2006, 08:24 PM
J.C. Whitney catalogue 707B-02, page 138: CM132950 for GM 0-90 ohms; CM128526 for all vehicles with 240-33 ohm Stewart-Warner gauges. As I said before, I seldom buy from Whitney because of quality concerns, but the GM unit in my M truck has been trouble-free so far.
jj
60Lark
08-27-2006, 02:06 AM
I installed the S.W. sending unit from Summit exactly like the one Dillo has pictured, in my 60 Lark, it is working perfectly.
http://im1.shutterfly.com/procserv/47b6dc00b3127cce8b441ec7192c00000000100CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
