Looking for confirmation or correction on some electrical stuff on my '60 Hawk.
1. There's a condenser on the coil...connects to the coil "+", right?
2. There's a condenser that was on the generator but I have went to a one-wire alternator. Is the condenser still needed? If so, connects to the output post (versus the case ground screw)?
3. My VDO electronic tach signal wire...connects to the coil "-" side, right?
4. Grounds... picked up a few heavy ground wires and figure more is better than less in an old car...my list of connections include:
5. Ammeter & alternator...as I say, put in a one-wire from Jegs along with their heavy gauge fused wiring to the B+ side of the starter solenoid. Plan is to bypass the ammeter by connecting the ammeter wires together (soldered). A voltmeter would replace the ammeter and wired to Acc of ignition switch. Question: what do I do with this black wire that was on the Batt terminal of the VR? I assume it has to get power (at least for the horn relay) but is the 12 ga wire to be connected to complete a circuit? (see pic)
If you spot anything that will cause my poor Hawk to burst in a ball of flames, please speak up!
- [*=1]Batt neg to a starter bolt
[*=1]alternator case to motor
[*=1]Motor to frame
[*=1]Motor to firewall
[*=1]Body to frame
[*=1]Gas tank to frame
[*=1]2nd body to frame in rear
[*=1]Dash gauges/harness to body (inspect and add)
[*=1]Oil gauge tube to firewall
