I know there is a lot of information on the forum about these springs. But, I don't know if this has ever been asked? Are the MOOG CC-655 springs a direct replacement for all the GM cars they fit? Or are they a variable rate upgrade for those GM cars? Being a CASO I have looked at these GM cars in Pick A Part (where I'll be tomorrow for their 50% off sale). Visually there is nothing to indicate the GM original springs as variable rate. I see no alteration in the coil spacing, taper windings etc.. On the other hand, if they actually are variable rate OEM spring (regardless of appearance), then I can get a comparable set of MOOG CC-655 "like" springs for very cheap. Thus, why I am asking the question
Which brings me to another point. My '64 Daytona was originally equipped with the Studebaker engine. Internet information lists that engine at 650 pounds. At some point prior to my purchase the engine was swapped to a Chevy 283 and subsequently I swapped that to a Corvette 350. Most of the engine weight charts list the SBC at 535-570 pounds. Being that I have an aluminum intake, water pump and what are often referred to as light weight iron head castings I'm incline to say my engine is no more than 550 pounds and likely less. I have no PS, A/C etc. This is a 100 pound weight reduction. I also swapped out the cast iron B/W A-12 transmission with a 700R4. The B/W A-12 was 200 pounds and the 700R4 150 pounds. So that is an additional 50 pounds reduction. Lastly I may swap the battery to the trunk and that would shift another 40-50 pounds off the front end.
I'm looking at close to 200 pounds of weight reduction from the front of the car. Has anyone else had a similar configuration with the MOOG CC-655 springs and can comment on the front ride height?
Thanks, Tom
Thanks, Tom
