Hey guys. We are putting a V-8 out of a 1990 chevy truck into my 49 r5. We want to keep the studes gas tank cause the chevys is huge. Anyway we know we need to change the fuel pump and all of that. My question would be for the sending unit and gauge. Id like to keep the original gauges and im doing all i can do accomplish that. What do i need to do to get the gas gauge to work on this fuel system. I know i have to convert to 12 volt. But anything else with the sending unit?
TBI fuel system conversion
If you change to 12 volts your current sending unit will work if you order a Runz voltage drop that will attach to your dash gauge. These units can be ordered from Randy Rundle at Fifth Avenue Antique Auto Parts at 785 632-3450 website www.fifthaveinternetgarage.comFrank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
Yeh i figured the gauge would need that voltage reducer. So the rest of the mech. Will work 12 volt? Also i need a high pressure electronic fuel pump for the tbi set up. Will i need to do anything special there except run the lines and hook it up?
I guess the main concern is the sending unit itself working in the 12 volt system.
Originally posted by Deadbodyman View PostYeh i figured the gauge would need that voltage reducer. So the rest of the mech. Will work 12 volt? Also i need a high pressure electronic fuel pump for the tbi set up. Will i need to do anything special there except run the lines and hook it up?
The two things you will need for the fuel pump is a good inlet and exit filter and a shut off switch even if you wire it into the ECM system. A roll over switch would be a good idea also. Just use the search function or Google it. The ford Taurus switch is usually used.
Bob
Originally posted by Deadbodyman View Posthey gunslinger, Yeh we are. We actually have to get new stuff. The old studes stuff wasnt even really there, and the new motor had the fuel sending unit, and pump IN THE TANK. And since we arent using the tank, we need to get a new pump, and i'll just get all new line. Thanks though!
That will give you the OEM pressure as well as the ability to find a fuel pump anywhere. The OEM last a long time as they are cooled by the fuel.
Bob
