As my original wiring is still in good shape I've decided to go with that and perhaps do a complete rewire later (if ever). So, I did an inspection, re-soldered a couple of suspect connections and started hooking everything back up. I need some I.D. help and advise.
In the frist pic below: Is this for the overdrive kickdown? The two terminated wires are white w/black stripe and the connected "loop" is white w/red stripe. If this is for the OD kickdown (which no longer applies as I've installed a 5-spd) what should I do with these wires?
The second pic: red wire with female bullet connector. Also for the OD (seems to reach that spot)?
The 3rd pic: flat woven ground strap about .5" wide, one end attached to the firewall. Thoughts on where the other end attaches?
