View Full Version : dual exhaust how to ????
bradnree
09-19-2006, 08:22 PM
I have a 1960 Lark with a 259 and want to put dual exhaust on it. I have A 2 1/4" and Flowmaster on the right. The muffler shop said that I would need a rear dump exhaust manifold so that the steering would be cleared and also to avoid extreme heat on the starter. Has any one installed the left side ??? How ???.....thanks Brad
klifton1
09-19-2006, 08:39 PM
Duel exhaust was optional. They used the std. manifolds. Any muffler shop, should be able to do it. The system is available thru many Studebaker venders.
Klif
55 Speedster
42 Champ Coupe
N8N
09-19-2006, 08:52 PM
A good but probably not inexpensive option would be to just get the headpipes from Silvertone (Don Simmons) he can make them with larger size tube if that's what you want, but with the factory bends. They're stainless, too. Then you will be able to R&R the starter without dropping the exhaust, which is handy.
GTtim
09-19-2006, 09:51 PM
Brad,
Get all the pipes from Simmons, put them in yourself. No big deal they fit like the factory ones. An afternoon project and your done.
Tim K.
'64 R2 GT Hawk
kamzack
09-20-2006, 12:12 AM
I installed 2 1/4 duel pipes on my 60 4dr, no problem with starter. Be sure ex. manifold studs are in good shape. I used the oem bracket near the frame riser that's just in front of differential. There happened to be a 64 Cruiser fram that had duels and took the left bracket from it. The frame on your 60 already ahs threaded bungs for it. made the job go easier. I'd find someone who's really interested in doing the job. Anyone that has parts cars will have one. Hope this helps.
Kim
60Lark
09-20-2006, 01:18 AM
When I put Flowmaster dual exhaust on my Lark, I found a local muffler shop that had the old catalogs that gave the measurements and where to bend the exhaust and tail pipes for my Lark. After I gave them a deposit they bent the pipes according to the measurements given in the catalog they had them ready and waiting for me the next day. They fit quite nicely, snug fit but no interference with the steering. Love the sound too ;)
http://im1.shutterfly.com/procserv/47b6dc00b3127cce8b441ec7192c00000000100CcNWTlozYsb http://im1.shutterfly.com/procserv/47b6dc03b3127cce970d7aafd15f00000010100CcNWTlozYsb
Studebaker Fever
60 Lark
51 Champion
Phil
Arnold, Missouri
52hawk
09-20-2006, 09:07 AM
I bought a tail pipe for my '60 from SASCO,very reasonable price.I think the complete system is all available from them.[it cost about $30 for the pipe,and $8 for shipping,took 2 days to get here]
LaSalle,Il
61Hawk
60Lark
09-20-2006, 05:08 PM
Brad, whatever you do - hats off to you for knowing it's DUAL exhausts ..... as in TWO of them. Duel exhausts would be a pain what with the exhausts always dueling with on another.;)
Miscreant adrift in
the BerStuda Triangle!!
sbca96
09-20-2006, 05:19 PM
The drivers side pipe goes forward, and than back next to the starter.
There is no special manifold required.
http://www.avantisource.com/exhaust.jpg
Tom
ROADRACELARK
09-20-2006, 07:52 PM
Brad,
Tom's description of the head pipes is correct, and is even so in the exploded pictures from the parts manual.:) Don't be confused with the rest of the picture not resembeling your system...this illustration is for the Avanti;)
Dan Miller
StudeDave57
09-20-2006, 08:01 PM
Interesting that the 'special order' system has a cross-over pipe, and the other does not...
One more example of being 'Ahead of their Time' perhaps? [:0] ;) [^]
StudeDave [8D]
V/P San Diego County SDC
San Diego, Ca
'54 Commander 4dr
'57 Parkview (it's a 2dr wagon...)
'57 Commander 2dr
'57 Champion 2dr
'58 Packard sedan
sbca96
09-20-2006, 08:36 PM
Yes sorry, the diagram is of the Avanti, I couldnt find anything else
online to link to. A Lark is similar ..... same head pipe, the rest
is different. You get the idea though.
Tom
ROADRACELARK
09-20-2006, 08:37 PM
Dave,
They actually refered to that as a "balance" or "equalizer" pipe.;) Add that to the "regular" mufflers AND resinators, really strangled[xx(] the Avanti and made it sound like a Hoover Vacuum Cleaner...woooooooosh
[B)]
Dan Miller
09-21-2006, 01:22 PM
Add that damned "equalizer" and it's REALLY a pain to get the exhaust on and off unless you add an unboltable flange to said equalizer pipe. Once that system is welded up (or even gets nicely oxidized together) it's hell to get that rigid pipe structure on or off the manifolds if you need to.:([xx(][8]:(
Also makes things more difficult when extracting or installing an engine. I'd rather not elaborate how I know these gems of insight.[}:)]
Miscreant adrift in
StudeDave57
09-21-2006, 02:35 PM
"They actually refered to that as a "balance" or "equalizer" pipe."
That's the word I was looking for, but couldn't seem to think of~ I knew my word was wrong, just had a 'brain fart' at that momment is all-
sorry 'bout that (in more ways then one!!!) [:o)] ;)
StudeDave [8D]
San Diego, Ca
'54 Commander 4dr
'57 Commander 2dr
'57 Champion 2dr
'58 Packard sedan
imported_n/a
09-22-2006, 12:48 AM
The equalizer/balance pipe was said to reduce exhaust noise and improve performance. But, as others have said, it does make the car harder to service.
